I would like to use the PullAllCaptureDataToFile from Python, via ACE Remote Control, to save data to the hard drive.
When I call PullAllCaptureDataToFile, I receive errors:
Error reading from AD4134: No method matches given arguments for PullAllCaptureDataToFile: (<class 'str'>, <class 'int'>, <class 'int'>, <class 'int'>, <class 'str'>)
This conflicts with the documentation from the ACE Remoting Console. When I type "HELP RUN PullAllCaptureDataToFile" into the ACE Remoting Console, it gives the following information for the function:
Arguments:
ExportPath (String):
The file path to export the data to. Note: directories must already exist, the file ending is trimmed, ignored and replaced with *.csv, *.bin or .bin.gz depending on file format and the device data source name is appended.
MaxSamples (Int32):
The maximum number of samples to pull to the file.
FileFormat (Int32):
The file format to use.
WaitTimeout (Int32):
The length of time to wait for data to become available to pull.
Tag (String):
The tag that was used to initiate the capture with.
My code is as follows:
client.Run('@AsyncDataCapture("dataset_name")')
client.PullAllCaptureDataToFile("C:\\Users\\userone\\AppData\\Local\\Analog Devices\\ACE\\ExportData\\AD4134\\dataset_name",
-1,
0,
5000,
"dataset_name")
which generates the error above:
I would be grateful for any help or a code snippet that works. Thank you!
* Added an explanation for the documentation produced by the ACE Remoting Console
[edited by: LeeL at 8:56 AM (GMT -5) on 18 Feb 2022]
