I have a AD9785 Evaluation Board. I connect USBto PC and run ACE software , it recognize board but in state it write State = Unkown and i can't reset or program it;
Hello yasharm1377 ,
Good day. What controller board are you using?
This link might be helpful - https://wiki.analog.com/resources/eval/dpg/eval-ad978x
Many Thanks,
Lorenz
I want to Program AD9785 without any fpga controller board. i have my own fpga board.
In DeviceManager it recognize driver but in ACE show state = unkown .
Can I connect AD9785Eval to ACE lonely ? Should be FPGA Controller Board with it ?
Hello yasharm1377 ,
Yes, ACE plugin requires DPG3 or SDP-H1 together with the Eval board.
What FPGA Board do you have? You can check whether there is an available reference design here: https://wiki.analog.com/resources/fpga
I design fpga board myself and it is based artix7. Is there any way to prgram ad9785 register with ace or with another program without DPG3 or SDP-H1 ?
Hello yasharm1377 ,
ACE would only work with DPG3 or SDP-H1.
You might need to write/create a software that would accompany the FPGA board you designed.
The registers can be set using the SPI detailed in page 21-35 of the datasheet. The Evaluation board schematic is also available in the wikipage.
Many Thanks,
Lorenz
