Main interrupt not detected EVAL-AD24248WD1BZ
Product Number: AD2428
I have 2 EVAL-AD2428WD1BZ, I am following instructions from eval-ad2428wd1bz_manual.pdf, for the master the selected configuration is master without microphone and the slave is using slave only with codec example, the connection to the EVAL-ADUSB2EBZ only in the main node, this is my configuration in sigma studio +,
When I try link-compile-download I receive the next error:
Do you have any advice or step by step guide to solve this situation, I appreciate any guidance.
Thank you in advance for your time.
  • Hi  ,
    The “Main running interrupt not detected” error in A2B usually points to a discovery or synchronization issue between the main node and its sub-nodes. Please check whether you are properly getting the SYNC signal.
    Before discovery, please check whether the "Program During Discovery" checkbox is enabled in the ADAU1452 block of the main node.
