AD2435W
Recommended for New Designs
The Automotive Audio Bus (A2B®) provides a multichannel, I2S/TDM link over distances of up to 15 m between nodes. It embeds bidirectional synchronous...
Datasheet
AD2435W on Analog.com
Hello Support Team Guys,
I'd like to know if we can use the I2C and SPI of AD2435 at the same time. Meanwhile, i can read the chipid via I2C. But i am not able to read the chipid via SPI. shall i disconnected the I2C connection? by looking at the datasheet, i think I2C and SPI can use the same time. if my saying is not right, please correct me.
Thanks & Best regards,
xiangzhi wu
Yes, you can use it. Please refer to the respective session under SPI operation in TRM and check which mode you are trying to use. See if your SPI pins are working in the same fashion described. if not please let me know.
Hello Arunk,
Thannks for your feedback. Because SPI driver is not ready, after modifying the driver, now it works fine.
xiangzhi wu
