Product Number: SS+ A2B plugin
Software Version: 1.3.2
The wiki/help for the SS+ A2B plug in does not seem to document how to use the power calculation section?
Specifically looking to where for a CFG4 RJ45 system the input voltage can be set, and where to add per node current draw values for peripherals that are powered by the Vbus power (e.g. 24V nominal, but it drops at each node)
As a general comment it would be very helpful if each dialog screen had a help button on it that takes you to the correct documentation page instead of hitting the menu help and it dropping you at the top of the Wiki tree.
