I am trying to use the BERT plug in. However, I am getting outlandish error ratio values. My hardware set up is simple and the boards are run in an office environment. Am I missing something?
The image below shows an error ratio of 1.03. How is that possible?
Alternatively, is there BERT plug in for Sigma Studio or is it just exclusively for Sigma Studio+.
I see you're using 2428s, so yeah, use SigmaStudio 4.7. SS+ is a definite work in progress (I'm being kind...). Note though there's some funnies about the BERT test in the errata (or maybe they're cleaned up now?). Also it might not be obvious but it only uses defined streams for the BERT test, so if you want to really test it you should create 16 down and 16 up to the last node in your network.
Hi Alben
Could you please check if any node is dropped or not before doing this PRBS test.? I hope you are using the latest version of SigmaStudio+(2.2) and plugin(1.3.2).
Since we couldn't able to reproduce the issue, could you tell me more details about your set up. It would be great if you can share the project file here. Looking forward to hear from you.
I am confused with what you are asking me to do. I am using the latest version of Sigma studio +. I am unsure on how to check the plug in version. However, I have the latest updates installed.
Hi Alben
Could you please share me the project file you are using ? so that i can do the BERT test from my end.
From sigmastudio+ help->about. You can find the sigmastudio version.
For Plugin version, you can navigate to Tools-> Add-in Browser and check.
