Deleted
Edit Notes
Deleted[edited by: Hermione at 2:46 PM (GMT -5) on 7 Mar 2024]
AD2428
Recommended for New Designs
The Automotive Audio Bus (A2B®) provides a multichannel, I2S/TDM link over distances of up to 15 m between nodes. It
embeds bidirectional synchronous...
Datasheet
AD2428 on Analog.com
SSM3582
Not Recommended for New Designs
The SSM3582 is a fully integrated, high efficiency, digital input stereo Class-D audio amplifier. It can operate from a single supply, and requires only...
Datasheet
SSM3582 on Analog.com
Deleted
Hi Hermione
could you please check if the audio host settings and the Audio of the A2b are aligning correctly. ?
The I2S Global configuration settings of the A2B Transceiver and the audio host should be similarly configured. Otherwise there is a chance that the actual data interpretation mismatches and causes noisy like output at the audio side. Let me know if its work for you.
