Hardware Setup on ADZS-AD2428MINI, EVAL-ADUSB2Z and molex ROAD NOISE CANCELLATION (RNC SENSOR SYSTEM)
Product Number: ADZS-AD2428MINI, EVAL-ADUSB2Z and molex ROAD NOISE CANCELLATION (RNC SENSOR SYSTEM)
Software Version: SigmaStudio Version 4.7
hi everyone,
i'm new to learn about the analog devices and to do my project i need help.
i have a  ADZS-AD2428MINI board and a  EVAL-ADUSB2Z  from ANALOG DEVICES and by using these boards i want to program a  ROAD NOISE CANCELLATION (RNC) SENSOR. i started to read "A2B Quick Start Guide" and installed sigmaStudio.
i don't know how to setup the hardware because my board is different to the boards wrote in the tutorial. could you please help me and tell me what can i do. thanks in advanced
Parents
  • Hi ladan,
    Thanks for contacting A2B support.
    ADZS-AD2428MINI board is a break-out board which can interface with EV-SOMCRR-EZKIT (via a 100-pin connector) or any custom board (via a 32 pin 0.1" header). You'd need a board which has Sigma DSP like ADAU1452/ADAU1451 as the A2B Main node etc. to program the board using Sigma Studio and EVAL-ADUSB2Z.
    Could you please confirm if you already have EV-SOMCRR-EZKIT?
    A supported SOM board needs to be attached to EV-SOMCRR-EZKIT along with ADZS-AD2428MINI which can act as A2B Main node. The example projects for this setup can be found in "C:\Analog Devices\ADI_A2B_Software-Rel19.x.x\Target\examples" folder.
    If not, you can use EVAL-AD2428WD1BZ board as A2B Main node which can be directly programmed using Sigma Studio.
    Thanks
    Shibin
Reply
  • Hi ladan,
    Thanks
    Shibin
Children
