Flashing U-Boot would be error on linux
Reference documentation "linux_add_in_user_guide.pdf" and see section 2.2.3,  The output result is as follows:
# /opt/analog/cces/2.8.3/ARM/openocd/bin/openocd -f interface/ice1000.cfg -f target/adspsc58x.cfg
Open On-Chip Debugger (Analog Devices CCES 2.8.0 OpenOCD 0.9.0-g5030ad7) 0.9.0
Licensed under GNU GPL v2
Report bugs to <processor.tools.support@analog.com>
adapter speed: 1000 kHz
Info : transports supported by the debug adapter: "jtag", "swd"
Info : auto-select transport "jtag"
halt and restart using CTI
trst_only separate trst_push_pull
Info : ICE-1000 firmware version is 1.0.2
Info : clock speed 1000 kHz
Info : JTAG tap: adspsc58x.adjc tap/device found: 0x228080cb (mfg: 0x065, part: 0x2808, ver: 0x2)
Info : JTAG tap: adspsc58x.dap enabled
Info : adspsc58x.dap: hardware has 3 breakpoints, 2 watchpoints
Info : adspsc58x.dap: but you can only set 1 watchpoint
Info : accepting 'gdb' connection on tcp/3333
and than, open operating as follows,
# /opt/analog/cces/2.8.3/ARM/gcc-arm-embedded/bin/arm-none-eabi-gdb u-boot-sc584-ezkit
GNU gdb (GNU Tools for ARM Embedded Processors 6-2017-q3-update) 7.12.1.20170417-git
Copyright (C) 2017 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=i686-linux-gnu --target=arm-none-eabi".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from u-boot-sc584-ezkit...done.
(gdb) target remote :3333
Remote debugging using :3333
0x00004884 in ?? ()
(gdb) load init-sc584-ezkit.elf
Loading section .text, size 0x51c lma 0x20080000
Start address 0x20080024, load size 1308
Transfer rate: 21 KB/sec, 1308 bytes/write.
(gdb)             //but this step will cause LED1 red(fault) why?    and continue with the next steps
Continuing.
^C
Program received signal SIGINT, Interrupt.
0x0000546e in ?? ()
(gdb) load u-boot-sc584-ezkit
Loading section .text, size 0x2b2fc lma 0x89200000
Loading section .rodata, size 0xabc9 lma 0x8922b2fc
Loading section .hash, size 0x2c lma 0x89235ec8
Loading section .data, size 0x21ae lma 0x89235ef4
Loading section .got.plt, size 0xc lma 0x892380a4
Loading section .u_boot_list, size 0x840 lma 0x892380b0
Loading section .rel.dyn, size 0x6d10 lma 0x892388f0
Loading section .dynsym, size 0x60 lma 0x8923f600
Loading section .dynstr, size 0x2a lma 0x8923f660
Loading section .dynamic, size 0x80 lma 0x8923f68c
Loading section .interp, size 0x14 lma 0x8923f70c
Start address 0x89200000, load size 259865
Transfer rate: 30 KB/sec, 10827 bytes/write.
(gdb) c
Continuing.
and we would see minicom output:
Hit any key to stop autoboot:  0
sc # dhcp
Speed: 100, full duplex
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 18
BOOTP broadcast 19
DHCP client bound to address 10.11.10.118 (31789 ms)
sc # set serverip 10.11.10.114
sc # run update
Using dwmac.3100c000 device
TFTP from server 10.11.10.114; our IP address is 10.11.10.118
Filename 'u-boot.ldr'.
Load address: 0x89000000
Loading: T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T
Retry count exceeded; starting again
And then keep showing this information.
Can you help me how to solve this problem? I can not find good solution in EngineerZone, so please holp me.
The local environment
Production: ADZS-SC584-EZLITE
Host PC: Ubuntu 20.04 64 bits
CCES Linux Version: 2.8.3
Linux Add-in Version: 1.3.1
