Dear sir or madam
I am also using the AD2428WB1BZ slave board and cannot get any output on the HP connector. You can find the XML config in the attachment. The DTX0 output of the AD2428 on the WBZ slave board provides proper stereo I2S signals. Nevertheless there is not output on PIN 19 + 20 of ADAU1761. I double checked all register settings but cannot seem to find any issue there. The line input (LAUX, RAUX) work just smooth. Can you please verify my xml setting of the ADAU1761?
Best regards
Marc
<?xml version="1.0" standalone="no"?> <ROM> <page modetype="Mode 0"> <action instr="writeXbytes" addr_width="2" data_width="1" len="6" addr="0" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="NonModRamAlloc">00 00 10 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="3" addr="16619" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Sample Rate Setting">7F</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="3" addr="16630" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.DSP Run Register">00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="3" addr="16384" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Clock Control Register">0F</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="8" addr="16386" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.PLL Control Register">00 01 00 00 20 03</action> <action instr="delay" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Delay">00 64</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="4" addr="16405" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Serial Port Control Registers">10 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="6" addr="16401" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.ALC Control Registers">00 00 00 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="3" addr="16392" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Microphone Control Register">00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="10" addr="16393" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Record Input Signal Path Registers">00 01 05 01 05 00 00 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="5" addr="16409" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.ADC Control Registers">33 00 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="16" addr="16412" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Playback Output Signal Path Registers">21 00 41 00 00 00 01 E7 E7 E4 E4 E4 00 03</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="4" addr="16407" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Converter Control Registers">00 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="5" addr="16426" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.DAC Control Registers">03 00 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="3" addr="16429" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Serial Port Pad Control Registers">FF</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="4" addr="16431" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Communication Port Pad Control Registers">A0 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="3" addr="16433" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Jack Detect Pad Control Register">08</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="1022" addr="2048" i2caddr="57" AddrIncr="4" CellName="Codec 0 : ADAU1761" ParamName="Program Clear Block 0">00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="1022" addr="2252" i2caddr="57" AddrIncr="4" CellName="Codec 0 : ADAU1761" ParamName="Program Clear Block 1">00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="1022" addr="2456" i2caddr="57" AddrIncr="4" CellName="Codec 0 : ADAU1761" ParamName="Program Clear Block 2">00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="1022" addr="2660" i2caddr="57" AddrIncr="4" CellName="Codec 0 : ADAU1761" ParamName="Program Clear Block 3">00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="17" addr="3068" i2caddr="57" AddrIncr="4" CellName="Codec 0 : ADAU1761" ParamName="Program Clear Block 4">00 00 00 00 00 00 00 00 00 00 00 00 00 00 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="3" addr="16629" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.DSP ON Register">01</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="7" addr="16576" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.CRC Registers">41 7F 06 7F 01</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="6" addr="16582" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.GPIO Registers">00 00 00 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="4" addr="16617" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Non Modulo Registers">10 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="7" addr="16592" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Watchdog Registers">00 04 00 00 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="3" addr="16619" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Sampling Rate Setting Register">01</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="3" addr="16626" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Routing Matrix Inputs Register">01</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="3" addr="16627" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Routing Matrix Outputs Register">00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="3" addr="16628" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Serial Data Configuration Register">00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="3" addr="16631" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.DSP Slew Mode Register">00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="3" addr="16632" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Serial Port Sample Rate Register">00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="4" addr="16633" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Clock Enable Registers">7F 03</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="1732" addr="2048" i2caddr="57" AddrIncr="5" CellName="Codec 0 : ADAU1761" ParamName="Program Data">00 00 00 00 00 FE E0 00 00 00 FF 34 00 00 00 FF 2C 00 00 00 FF 54 00 00 00 FF 5C 00 00 00 FF F5 08 20 00 FF 38 00 00 00 FF 80 00 00 00 00 00 00 00 00 00 00 00 00 00 FE E8 0C 00 00 FE 30 00 E2 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF E8 07 20 08 00 00 06 A0 00 FF E0 00 C0 00 FF 80 07 00 00 00 00 00 00 00 FF 00 00 00 00 FE C0 22 00 27 00 00 00 00 00 FE E8 1E 00 00 FF E8 01 20 00 FF D8 01 03 00 00 07 C6 00 00 FF 08 00 00 00 FF F4 00 20 00 FF D8 07 02 00 FD A5 08 20 00 00 00 00 E2 00 FD AD 08 20 00 00 08 00 E2 00 FD 25 08 20 00 00 10 00 E2 00 FD 2D 08 20 00 00 18 00 E2 00 FF E8 08 20 00 00 20 00 E2 00 00 45 1F 20 00 00 35 08 22 00 00 00 0A A0 00 FF E5 18 22 00 00 00 09 A0 00 00 38 00 EA 00 00 48 00 F2 00 00 38 00 C0 00 00 00 00 00 00 00 00 00 00 00 FF EC 01 21 00 00 04 00 A1 00 00 00 00 00 00 FF E5 08 22 40 00 50 00 E2 00 00 48 00 C0 00 00 00 00 00 00 00 57 FF 20 00 FF E5 08 22 00 00 58 00 E2 00 00 58 0B 20 00 00 28 00 E2 00 00 85 1F 20 00 00 75 08 22 00 00 00 0D A0 00 FF E5 18 22 00 00 00 0C A0 00 00 78 00 EA 00 00 88 00 F2 00 00 78 00 C0 00 00 00 00 00 00 00 00 00 00 00 FF EC 01 21 00 00 04 00 A1 00 00 00 00 00 00 FF E5 08 22 40 00 50 00 E2 00 00 88 00 C0 00 00 00 00 00 00 00 57 FF 20 00 FF E5 08 22 00 00 58 00 E2 00 00 58 0E 20 00 00 68 00 E2 00 00 25 08 20 00 FF D8 0F 02 00 00 90 00 E2 00 FF E8 10 20 00 00 E0 00 E2 00 00 6D 08 20 00 00 A8 00 E2 00 00 6D 08 20 00 00 C0 00 E2 00 00 05 08 20 00 00 B0 00 E2 00 00 0D 08 20 00 00 C8 00 E2 00 00 15 08 20 00 00 B8 00 E2 00 00 1D 08 20 00 00 D0 00 E2 00 FF F5 08 20 00 01 38 00 E2 00 00 DD 08 20 00 00 E5 08 22 48 00 00 00 00 00 FF ED 08 20 26 01 38 00 E2 00 00 FD 08 20 00 FF ED 13 22 48 00 DD 08 20 00 01 1D 08 20 25 01 20 00 E2 00 01 0D 08 20 00 FF ED 13 22 48 00 DD 08 20 00 01 2D 08 20 25 01 30 00 E2 00 01 45 08 20 00 00 00 00 00 00 01 50 00 F0 00 01 55 08 20 00 FF ED 13 22 48 01 3D 08 20 00 FF F5 08 20 25 01 38 00 E2 00 00 DD 08 20 00 00 E0 00 E2 25 00 ED 08 20 00 00 FD 08 22 40 01 48 00 E2 00 00 FD 08 20 00 01 4D 14 22 00 01 00 00 E2 00 01 20 00 C0 00 00 07 FF A0 00 01 00 00 C0 00 00 00 00 00 00 00 AF FF 20 80 00 98 00 E2 00 00 C7 FF 40 80 00 A0 00 E4 00 FF ED 08 20 00 FF EF FF 22 40 01 10 00 E2 00 01 30 00 C0 00 00 07 FF A0 00 01 10 00 C0 00 00 00 00 00 00 00 AF FF 20 80 00 9D 08 22 00 00 98 00 E2 00 00 C7 FF 40 80 00 A5 08 44 00 00 A0 00 E4 00 00 ED 08 20 00 01 3D 08 22 40 00 00 00 00 00 00 F0 00 F0 00 00 00 00 00 00 01 7D 08 20 00 FF E8 12 34 00 01 6D 08 22 48 01 78 11 20 40 01 68 11 34 40 01 78 11 20 25 01 68 11 34 25 01 90 00 E2 00 01 88 00 F2 00 01 7D 08 20 00 01 8D 08 22 00 01 6D 08 34 00 01 95 08 22 00 01 70 00 E2 00 01 80 00 F2 00 01 75 08 20 08 FF ED 1F 20 00 01 75 08 20 25 01 70 00 E2 00 FF ED 1F 22 40 01 A0 00 E2 00 01 75 08 20 00 FF E8 12 22 40 01 70 11 30 48 01 A5 08 20 00 FF E8 12 20 27 01 A0 00 E2 00 01 A0 00 C0 00 00 17 FF 20 00 01 58 00 E2 00 00 1F FF 20 00 01 60 00 E2 00 FF E8 13 20 00 01 F0 00 E2 00 00 05 08 20 00 01 B8 00 E2 00 00 0D 08 20 00 01 D0 00 E2 00 01 5D 08 20 00 01 C0 00 E2 00 01 65 08 20 00 01 D8 00 E2 00 00 2D 08 20 00 01 C8 00 E2 00 00 2D 08 20 00 01 E0 00 E2 00 FF F5 08 20 00 02 48 00 E2 00 01 ED 08 20 00 01 F5 08 22 48 00 00 00 00 00 FF ED 08 20 26 02 48 00 E2 00 02 0D 08 20 00 FF ED 13 22 48 01 ED 08 20 00 02 2D 08 20 25 02 30 00 E2 00 02 1D 08 20 00 FF ED 13 22 48 01 ED 08 20 00 02 3D 08 20 25 02 40 00 E2 00 02 55 08 20 00 00 00 00 00 00 02 60 00 F0 00 02 65 08 20 00 FF ED 13 22 48 02 4D 08 20 00 FF F5 08 20 25 02 48 00 E2 00 01 ED 08 20 00 01 F0 00 E2 25 01 FD 08 20 00 02 0D 08 22 40 02 58 00 E2 00 02 0D 08 20 00 02 5D 14 22 00 02 10 00 E2 00 02 30 00 C0 00 00 07 FF A0 00 02 10 00 C0 00 00 00 00 00 00 01 BF FF 20 80 01 A8 00 E2 00 01 D7 FF 40 80 01 B0 00 E4 00 FF ED 08 20 00 FF EF FF 22 40 02 20 00 E2 00 02 40 00 C0 00 00 07 FF A0 00 02 20 00 C0 00 00 00 00 00 00 01 BF FF 20 80 01 AD 08 22 00 01 A8 00 E2 00 01 D7 FF 40 80 01 B5 08 44 00 01 B0 00 E4 00 01 FD 08 20 00 02 4D 08 22 40 00 00 00 00 00 02 00 00 F0 00 00 00 00 00 00 02 8D 08 20 00 FF E8 15 34 00 02 7D 08 22 48 02 88 14 20 40 02 78 14 34 40 02 88 14 20 25 02 78 14 34 25 02 A0 00 E2 00 02 98 00 F2 00 02 8D 08 20 00 02 9D 08 22 00 02 7D 08 34 00 02 A5 08 22 00 02 80 00 E2 00 02 90 00 F2 00 02 85 08 20 08 FF ED 1F 20 00 02 85 08 20 25 02 80 00 E2 00 FF ED 1F 22 40 02 B0 00 E2 00 02 85 08 20 00 FF E8 15 22 40 02 80 14 30 48 02 B5 08 20 00 FF E8 15 20 27 02 B0 00 E2 00 02 B0 00 C0 00 00 9F FF 20 00 02 68 00 E2 00 00 A7 FF 20 00 02 70 00 E2 00 02 DD 08 20 00 FF E8 17 34 00 02 CD 08 22 48 02 D8 16 20 40 02 C8 16 34 40 02 D8 16 20 25 02 C8 16 34 25 02 F0 00 E2 00 02 E8 00 F2 00 02 DD 08 20 00 02 ED 08 22 00 02 CD 08 34 00 02 F5 08 22 00 02 D0 00 E2 00 02 E0 00 F2 00 02 D5 08 20 08 FF ED 1F 20 00 02 D5 08 20 25 02 D0 00 E2 00 FF ED 1F 22 40 03 00 00 E2 00 02 D5 08 20 00 FF E8 17 22 40 02 D0 16 30 48 03 05 08 20 00 FF E8 17 20 27 03 00 00 E2 00 03 00 00 C0 00 01 AF FF 20 00 02 B8 00 E2 00 01 B7 FF 20 00 02 C0 00 E2 00 02 6D 08 20 00 FD 60 00 E2 00 02 75 08 20 00 FD 68 00 E2 00 02 C5 08 20 00 FD B8 00 E2 00 02 BD 08 20 00 FD B0 00 E2 00 00 00 00 00 00 FE 30 00 00 00 00 00 00 00 00 FE C0 0F 00 00 00 00 00 00 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="98" addr="0" i2caddr="57" AddrIncr="4" CellName="Codec 0 : ADAU1761" ParamName="Param">00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 FF 00 02 22 26 00 80 00 00 00 00 00 FF 00 02 22 26 00 80 00 00 00 00 00 00 00 00 00 01 00 00 10 00 00 80 00 00 00 00 00 01 00 00 10 00 00 80 00 00 00 00 10 00 00 80 00 00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="3" addr="16619" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Sample Rate Setting">01</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="3" addr="16630" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.DSP Run Register">00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="3" addr="16438" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Dejitter Register Control">00</action> <action instr="writeXbytes" addr_width="2" data_width="1" len="3" addr="16438" i2caddr="57" AddrIncr="0" CellName="Codec 0 : ADAU1761" ParamName="IC 1.Dejitter Register Control">03</action> </page> </ROM>
