Skip navigation
This Question is Assumed Answered
1 "correct" answer available (4 pts) 1 "helpful" answer available (2 pts)
5,121 Views 16 Replies Last post: Oct 1, 2009 9:59 AM by MikeSmithCanada RSS 1 2 Previous Next
MikeSmithCanada Regular Contributor 141 posts since
Mar 27, 2009
Currently Being Moderated
Sep 26, 2009 3:07 PM
Causing message on VDSP screen and then pausing
I thought the following would put out a message and cause VDSP to pause till the gets was completed
-- but it does not.  I would prefer not to have to use break points
I used to pop up some sort of response window in VDSP -- just can't remember syntax -- any body help. Not sure what to look for under "help"
#include <stdio.h>
void GetBuffer(char *buff) {
    puts("If gets( ) is not waiting --  then set a break point at this line of code\n");
     puts("Waiting for you to hold the switches down and then press return");
      gets(buff);
Thanks
CraigG Analog Employee 444 posts since
Jan 29, 2009
1. Sep 28, 2009 5:26 AM in response to: Michael Smith
Re: Causing message on VDSP screen and then pausing
Hi Mike,
in a trivial example (e.g. 'do something'... GetBuffer()... 'Do something else'), the code you have posted below does cause an "stdin" pop-up that 'pauses' the application while it waits for input. This wouldn't occur if you have redirected STDIO in your application away from the default PrimIO device - is this possibly the case? Also note that such a 'halt' will only halt the core, while peripherals and DMA operations will continue to function.
Jan 29, 2009
6. Sep 28, 2009 10:30 AM in response to: Michael Smith
Re: Has a change occurred in HPPC-ICE Driver
Hi Mike.
sorry for the delay in getting back to you. Firstly, regarding redirecting STDIO; this is something that you would know you have done. It requires that you register a new DevEntry structure device driver using add_devtab_entry. It's explained in full detail in the Compiler and Libraries Manual under 'C and C++ Run-Time Library Guide'->'File I/O Support'. But it's something that you have to explicitly do in your application, rather than being an IDDE option for example.
I tried the DXE you provided in your previous post, and it produces a pop-up stdin window. I always use an HPPCI-ICE too, but also tested with HPUSB-ICE and Simulator and saw the expected pop-up on all three.
One thing that now occurs to me, is that you mentioned you are trying to avoid using breakpoints, are you removing the breakpoints from the Active/Automatic list in the IDDE? If this is the case, the required __primIO breakpoint may be getting removed, which could cause the problem. Can you please check under 'Settings'->'Breakpoints'->'Automatic' to see if this breakpoint is enabled or disabled.
thanks,
Craig
GlenA Analog Employee 10 posts since
Mar 12, 2009
10. Sep 29, 2009 10:20 AM in response to: Michael Smith
Re: 'Print' I/O breakpoints work -- but not 'get' I/O breakpoints
Hi Mike,
Just a shot in the dark here but from prior posts I know that you tend to use .vbs scripts for various purposes in your environment. Is it possible that in one of your scripts you have set the ADspApplication::Interactive flag to False? This would have the effect of disabling the popup while still allowing other non-blocking STDIO operations such as puts() or printf() to continue to function.
Glen
NormY Analog Employee 3 posts since
Jun 23, 2009
12. Sep 30, 2009 4:29 PM in response to: Michael Smith
How did you change your JTAG settings?  With a Python script?  If a script is still running in the background, the stdin dialog won't be displayed.  A quick way to check if a script is still running is to look at the Debug/Halt Script menu item.  If it's enabled, then a script is still running.
More Like This
  • Retrieving data ...
Bookmarked By (0)
