We are using Audio extender card with BF-533 Ez-Kit Lite. We are receving digital data through ADAV801 and SPOrt0.
This data is transmitting through AD1938 on Sport1.
We have provided 0-db sine tone as input, Then in the output we have observed -12db difference in amplitue level. When we check in Sport1Tx buffer, we found 0x7FFF000, means no attenuation in the receiver. So, problem can be in ADAV1938.
Anybody is having idea whether AD1938 will provide any attenuation.
with regards,
sunil
Hello Sunil,
Some possible reasons why you may be seeing this:
If you would like more specific information on the converters (AD1938 and ADAV801) I'd recommend you contact Linear Applications Support through their email support system:
https://form.analog.com/Form_Pages/support/standard_linear/contacttechSupport.aspx
Hope this helps.
Tom
Hi Sunil,
Are registers 6-13 (DAC volume control) on the 1938 set to 0 for no attenuation?
Gabby
Thanks for the response. We have set all DAC volume control registers to zero. We are operating at 48KHz sampling rate, in the data sheet we have checked DAC frequency response for 48Khz. There is no attenuation.
with regards,
sunil
