简体中文 | 日本語
1 2 Previous Next 22 Replies Latest reply: Apr 22, 2012 9:54 PM by SimonB RSS
compile linux for blackfin 548
AlexNikitin Contributor
Currently Being Moderated
Hi!
I'am trying to compile linux for blackfin 548 with this document  http://docs.blackfin.uclinux.org/doku.php?id=quick-start:bf537-stamp, but receive many errors
ln: creating symbolic link `config.arch' to `vendors/AnalogDevices/BF548-EZKIT/config.arch': Function not implemented
config/setconfig: line 236: ARCH: command not found
Makefile:412: /mnt/disk1/linux-2.6.x/arch//Makefile: No such file or directory
make[2]: *** No rule to make target `/mnt/disk1/linux-2.6.x/arch//Makefile'.  Stop.
make[1]: *** [oldconfig_linux] Error 2
make[1]: *** [dep] Error 1
make: *** [AnalogDevices/BF548-EZKIT_default] Error 2
I see is not compile because script don't see the ARCH, and cant get Makefile for blackfin. Why?
Can anybody help me?
  • 1. Re: compile linux for blackfin 548
    MarkBishop Regular Contributor
    try 'make distclean' before you try and configure/build the kernel.
  • 2. Re: compile linux for blackfin 548
    Hi. Thank for your answer. But I try to 'make distclean' and 'make clean' many-many times. And nothing change
    I'am try 'make AnalogDevices/BF548-EZKIT_default' but still has same error
  • 3. Re: compile linux for blackfin 548
    Aaronwu Analog Employee
    please run make bugreport and attache the generated bugreport.tar.gz
  • 4. Re: compile linux for blackfin 548
    This is bugreport
  • 5. Re: compile linux for blackfin 548
    Please have the blackfin linux toolchain (and maybe packages on host also) set up properly first, some information in:
    http://docs.blackfin.uclinux.org/doku.php?id=toolchain:installing
    http://docs.blackfin.uclinux.org/doku.php?id=installing_linux
  • 6. Re: compile linux for blackfin 548
    Hmm. I installing toolchain (2008) from disk with EZKIT - has error.
    Then I install toolchain (2011) from blackfin.linux.org - has same error/
    Then I try install by 'sudo apt-get install blackfin-toolchain-uclinux'
    but has error
    Reading package lists...
    Building dependency tree...
    Suggested packages:
      blackfin-toolchain-elf
    The following NEW packages will be installed:
    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
    Need to get 0B/69.6MB of archives.
    After unpacking 223MB of additional disk space will be used.
    (Reading database ... 33321 files and directories currently installed.)
    Unpacking blackfin-toolchain-uclinux (from .../blackfin-toolchain-uclinux_2010R1-rc4_i386.deb) ...
    dpkg: error processing /var/cache/apt/archives/blackfin-toolchain-uclinux_2010R1-rc4_i386.deb (--unpack):
    trying to overwrite `/opt/uClinux/bfin-uclinux/info/stabs.info', which is also in package blackfin-toolchain
    dpkg-deb: subprocess paste killed by signal (Broken pipe)
    Errors were encountered while processing:
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    maybe this toolchain is older version?
  • 7. Re: compile linux for blackfin 548
    If I were you I would try the pre-built binaries released on the website, the toolchain version should match your target distribution version, now we usually recommend customer to use 2011R1 release.
  • 8. Re: compile linux for blackfin 548
    I remove all toolchains and install new by "sudo apt-get install blackfin-toolchain-uclinux blackfin-toolchain-linux-uclibc". But has errors
    In '/mnt/windows' is located 'blackfin-linux-dist'
    And then i try 'make AnalogDevices/BF548-EZKIT_default'. And have this log:
    find vendors -mindepth 2 '(' -name .svn -prune ')' -o -type f -name Kconfig -print | sed 's:^:source ../:' > vendors/Kconfig
    config/mkconfig > Kconfig
    make AnalogDevices/BF548-EZKIT_defconfig
    make[1]: Entering directory `/mnt/windows'
    make clean > /dev/null 2>&1
    cp vendors/AnalogDevices/BF548-EZKIT/config.device .config
    chmod u+x config/setconfig
    yes "" | config/setconfig defaults
    *********************** NOTICE ****************************
    There is no preset config for linux-2.6.x on platform AnalogDevices/BF548-EZKIT.
    If you choose to continue you will have to setup a linux
    config from scratch which is a very complex task.
    You will find it easier if you can copy a config.linux-2.6.x
    from another platform that is similar.
    If you know what you are doing press <ENTER> otherwise
    Type ^C to abort.
    make[2]: Entering directory `/mnt/windows'
    KCONFIG_NOTIMESTAMP=1 make ARCH= CROSS_COMPILE= -C linux-2.6.x oldconfig
    make[3]: Entering directory `/mnt/windows/linux-2.6.x'
    make[3]: Leaving directory `/mnt/windows/linux-2.6.x'
    make[2]: Leaving directory `/mnt/windows'
    config/setconfig final
    #make dep
    make[1]: Leaving directory `/mnt/windows'
    make
    make -C tools/sg-cksum
    make[2]: Entering directory `/mnt/windows/tools/sg-cksum'
    make[2]: `cksum' is up to date.
    make[2]: Leaving directory `/mnt/windows/tools/sg-cksum'
    ln -sf /mnt/windows/tools/sg-cksum/cksum tools/cksum
    Makefile:484: /mnt/windows/linux-2.6.x/arch//Makefile: No such file or directory
    make[3]: *** No rule to make target `/mnt/windows/linux-2.6.x/arch//Makefile'.  Stop.
    make[2]: *** [linux_oldconfig] Error 2
    ln: creating symbolic link `tools/cksum' to `/mnt/windows/tools/sg-cksum/cksum': Function not implemented
    make[1]: *** [tools/cksum] Error 1
  • 9. Re: compile linux for blackfin 548
    James.Kosin Regular Contributor
    Question:
    Are you trying to compile on a mounting point to a Windows partition?
  • 10. Re: compile linux for blackfin 548
    I'am using coLinux. In my coLinux cofs0 mounting to /mnt/windows, in settings file adi.conf I set cofs0=E:\blackfin-linux-dist-2011R1-RC3\ (the directory with unpacked linux dist). I think error not here?
  • 11. Re: compile linux for blackfin 548
    Recommend you strongly to move to the Linux environment for develop, other than the colinux on Windows, actually we have long no effort on mainting the coLinux. Thanks.
  • 12. Re: compile linux for blackfin 548
    Hmm. Then why CD with EZKIT contain coLinux?
  • 13. Re: compile linux for blackfin 548
    sonic Analog Employee
    The CD is for 2008R1 release, which is obsolete.
    Now we only support 2011R1 release, which doesn’t include colinux.
  • 14. Re: compile linux for blackfin 548
    But I'am trying to compile 2008 release too, and has errors.
1 2 Previous Next
More Like This
  • Retrieving data ...
Legend
  • Correct Answers - 4 points
  • Helpful Answers - 2 points
