简体中文 | 日本語
3 Replies Latest reply: Mar 2, 2012 1:45 PM by MichaelS RSS
Access to host file from a DXE executable when using automation API
msonet Contributor
Currently Being Moderated
I am doing experiments with automation of the VDSP IDDE starting from the bigdump.zip example in the discussion [http://ez.analog.com/message/9951]. Now I am able to load and run a DXE file from the Python script.
My DXE project uses an external file to load test vectors. This DXE runs fine when loaded and run manually from a project.
When I load and run the DXE file from a Python script using the ADspProcessor interface, the programs fails when trying to load the external file.
The test vector file is opened with a relative path. So I suspect the debugger has no knowledge of my DXE working directory.
Is there a property of the Idde where I could specify a working directory to avoid this problem ?
Mathieu
More Like This
  • Retrieving data ...
Legend
  • Correct Answers - 4 points
  • Helpful Answers - 2 points
